Home Forums Gen V Badge removal
      no holes, just dental floss and heat gun
      If you have a braided type of fishing line you can get through the adhesive a lot easier. Then some orange good adhesive remover or WD40 to the off what you cannot roll off with your finger.
      Is it correct to assume the GTS badges on the GenV are fixed with adhesive and can be removed with typical techniques (hot air gun, dental floss, etc)? Or are they mounted through the body panel….
