Home Forums General Car idles and dies
      Original owner of a 96 gts with 85k miles, never had any major issues till recently. It started to crank & crank till it finally ignited. There are times that it ignites right off, I had taken it to my own mechanic & Dodge dealer and left it for a few days. They both claimed it started every time the key was turned . You can guess what happened once in my own garage, symptoms came back. I have a new problem, once ignited and idling for as long as 5 minutes or more, it stalls, cranks it again, idles but stalls. Here’s the kicker, after doing it for a few times it idles just fine and things are back to normal, as far as I can tell. However, I don’t have enough of you know what to take it out for a spin.
      I have to mention that I don’t know a whole lot about how things work around the engine, but I imagine given the symptoms to a master tech, should give them a point of direction. I have put in a new battery, Alternator, Fuel filter, Crankshaft sensor. I am looking in to changing or cleaning the Idle control valve which also make the engine stalls for no reason.
      Please, if any body gone through the same situation, I can really use your suggestions or thoughts.
