Home Forums Gen V Check your weather stripping.
      Mine is doing the same on the passenger headlight…
    • Andrew Wheeler
      Yeah easy fix, I think the factory weather stripping is a tad too long on that one side and it gets pinched when the hood is closed. Trim about a 1/4 inch off of it and it will close much better.
      Also the 3M automotive grade double sided tape is wider than what the factory used so it will adhere better. I just went in there and removed any old adheasive cut the new tape and re applied the weather stripping.
      Andy
      Thanks for info…I’ll take a look today…
      Cool, thanks for the tip!
      Good info. Thanks
      Ok about to drop some really complex, cutting edge, hard hitting tech discussion here. 😀
      I noticed my TA, with 1,600 miles on it, started losing it’s drivers side head light weather stripping. Silly easy fix and I would rather use a better 3M tape than the factory replacement would use so I redid it yesterday. Rotated the photos in photobucket so if theyre upside down give them a few minutes.
