Home Forums Viper Competition Coupe/ACR-X/GTS-R Comp Coupe Caster
      Need help with Caster adjustment on Comp Coupe.
      A-arms have Monoball and VCC Camber shims.
      Current LF caster is +3.0, RF is +3.2. Looking to get both side to around +6.0
      How to I make the change? Is it with the aluminum spacers between A-arm and monoball or with the Camber shims?
      The 4 bottom A-Arm monoball spaces are all equal in length.
      Currently all the front shims are the “E” shim. LF Camber is -2.5 RF Camber is -2.7
      Would also like to get Camber to the -3.5 range.
      Thanks.
