Home Forums Gen V Competition alignment and ride height
      I would like to have your input and based on track experience what do you think of my alignment and ride height settings.
      My car is a viper ta with MCS suspension, spherical bearing conversion, shock relocation and running Michelin slicks on 18×12 front wheels and 18×13 rear wheels. Running in Bahrain international circuit which is a F1 circuit which has smooth surface, slow and high speed corners and elevation changes.
      I’m about to install them in the next couple of days and will be my first time trying these mods on the car. Previously I was running OEM suspension and running OEM ride height as it isn’t adjustable and these alignment settings:
      Front:
      Camber: -3 to -3.25 degrees
      Caster: honestly I didn’t gave it much attention and used to run both side equal to eachother
      Toe: 2 mm per side toe out
      Rear:
      Camber: -2.5 to -2.8 degrees
      Caster: The same as above I just kept them equal both sides
      Toe: 1 mm per side out
      These above settings were on Michelin and Pirelli slicks on 18×12 front wheels and 18×13 rear wheels.
      From what I gathered and read here in the forums that caster is very important and very sensitive to the viper so I’ll look into what figures to run. In regards to my alignment settings the majority that I have spoken to mentioned that my figures are aggressive but the reason behind that is due to me running slicks which work better with more camber and the toe figures although might be a key to the car being a bit loose than my liking it helps a lot to get rid of the understeer and help with better rotation if you know what I mean.
      However now with the suspension changes I would to try a different alignment as I’m still having an issue getting the power down especially at the apex and this is loosing me time and would like to fix that.
      Can you please share what had worked for you especially who has been tracking vipers for a while especially ACR’s, ACRX and comp coupes. Also what are your thoughts if I should run what I was running previously. In regards to ride height I’m looking to run 4″ in the front and 5″ in the rear with the MCS.
      Looking forward to your inputs.
      Thanks
      Yousif
