Home Forums Gen III / Gen IV Convertible glass seperating
      Still under warranty? If so, Id take it to the dealer and have it covered.
      Sort of, under the Canadian version of the maxcare warranty but its not in the fine print, car is going in next week for a few various warranty items just wanted to check options if not covered.
      Gotcha. If not covered, Im sure a good upholstery shop could fix it for you, assuming they’ve worked with convertible tops and the like before.
      The convertible glass on my Gen IV is separating(from the window to the fabric). I see online most recommended to use the 3M window sealant, which i’m sure would be the ultimate permanent bond. Now id rather keep it not totally permanent in case something happened to ether the top or the window and either had to be replaced. What would be a suitable adhesive to bond the window back to the fabric?
