Home › Forums › Doug Shelby Engineering › DSE-VP-BA-001 – SRT-10 CNC Aluminum Quick Release Battery Cover
A quick product update – the battery cover finish is now a matte black anodize and there is an engraved battery logo symbol on the face. Shown with and without battery charger connector option.
This part improves upon the OEM battery cover and allows for quicker battery access.
– Quick Battery Access for Convenience, Safety, and Emergency Situations
– NO DRILLING!! Uses all OEM holes. No modification of car whatsoever, car can easily return to stock.
– Remove panel in seconds, not minutes. Requires common Phillips screwdriver instead of Torx bit.
– Perfect for Track or Street Driven Cars: Lighter and Stronger Than Stock
– Low-Gloss Black Powder Coat Compliments Interior
– Stainless Steel and Aluminum Aircraft Grade Quick-Release Phillips Head Fasteners
– Includes Mounting Points for Bulkhead Mount Battery Tender Connector, P/N DSE VP-BA-002photo1-2.jpgphoto9.jpgphotoc-1.jpgphotoa.jpg
As an added accessory, the cover with battery tender connector allows quick easy charging access to the battery:
DSE-VP-BA-002 – SRT-10 Quick Release Battery Cover with Battery Tender Connector:
– Includes features of DSE-VP-BA-001
– Quick, Convenient Way to Keep the Battery Charged – No Open Hoods, Windows or Hatches
– Connector is Accessible Through Rear Vents Above Diffuser, Just Plug Battery Tender In
– Hardwired Directly to Battery Using Ring Terminals for Most Electrically Efficient Charging Possible
– Strong Powder Coated Black Aluminum / Stainless Steel Bracket Mounts to DSE Battery Cover
– SAE 2 Pin Connector with Cap (Battery Tender Compatible), Car Battery Harness with 7.5A fuse
– No modification of car, ring terminals on car harness attach directly to OEM battery lugs
– Total Weight of DSE-VP-BA-002 is Lighter Than OEM Steel Cover PlateMore information here: http://dougshelbyengineering.com/uploads/DSE_Dodge_Viper_SRT-10_Battery_Cover_and_Charger_Connector_Rev3.pdf
Available for purchase at: http://dougshelbyengineering.com/Viper.html
