Home Forums The Track fried the a/c at the track
Viewing 8 reply threads
      Check system with dye for obvious leaks…especially checking for damage to condenser or connections at compressor.
    • fuggles
      Thanks much. Do you know if the factory adds dye? The engine bay looks clean.
      Hey, Kent… were you terrorizing somebody running slicks? πŸ˜€ you might have picked up some FOD to that condenser. Although it’s probably more likely that you just accelerated your existing slow leak…
      Rich
      I would say no on factory fill having dye. Admittedly, when I occasionally recharge one st home, I use dye in the R-134a. Sometimes, it takes a bright UV light as well as proper goggles to see a leak. I have had better luck with dye than my sniffer.
      Easiest to find and fix would be the “O” rings where the lines connect to the compressor. This area runs HOT…more so on a track day. “O” ring kit about $6. Also check your Schrader valves at high and low pressure ports…with spit…just like on a bike tire. πŸ™‚
      Good hunting.
    • Bill Pemberton
      Steve, since he is a racer, should he get Ken Schrader valves next time? Ha, couldn’t resist, but you are always a great wealth of information and I am sure many have benefited from your wisdom.
      Good one Bill !! I am HOPING for a simple fix here…racers need tire money !!!
    • Bill Pemberton
      Living near Indy you definitely know your racers too!
    • fuggles
      Thanks for the tips Steve. I’m not fond of the dye. I use bottles with out dye. Dye just makes a mess. πŸ™‚ Spit test on the way. lol. And more tire money is good. πŸ™‚
      Hi Rich. I was terrorizing an F430 for a bit. Great fun. No slicks, though I did find a glob of rubber on the condenser and a few ricochets on the hood. No damage done. πŸ™‚ Probably right. I will test for leaks.
      Thanks.
      The A/C was working fine before the track day. On the way home no A/C. Very hot air. I did not run the a/c on the track. πŸ™‚
      There was a slow leak before. I had to recharge the system once in the two months I’ve had the car.
      Anyone have this problem? What problems should I look for?
