siphon gas out of tank,,,, unbolt and pull out fill tube. I also removed left rear tire, removed left rear inner panel so I could easily access filter to disconnect it too….. by having that access you can also use something to help pry the tank rearward,,,, I had to do this cause the tank, being plastic had changed its shape a little and needed a little coaxing to squeeze thru the hole,,,, if you have all things unhooked, disconnected, straps off IT WILL come out just gotta help it,,, I used my sons hockey stick as it fit perfect,,, i’m sure I looked stupid doing it but in and out ,,,, badda bing badda boom,,,,, good luck finding a new module,,,, probably cost more than the car. If you just need a sending unit I can tell which one I used to have gauge work like new….
