Home Forums TKO Motorsports, LLC Gen 5 TKO ACR viper
    • James Metheney
      That is one incredible ride :dropdev:
    • TKO MOTORSPORTS TEAM
      Thank you James
      Viper in Switzerland ???
    • James Metheney
      You mean my Viper, or Gen V in general?
      Your viper. Viper has to be a rare breed in Switzerland. By the way love your country one of the most beautiful places on the planet.
      Over the top!!!
    • James Metheney
      Thanks a lot, TKO Motorsports. It is quite a rare sight over here, correct. Interestingly enough, even though we are a very small country, we supposedly have a big number of Vipers compared to the bigger countries around. But if I see two or three on the road in any year, it’s a lot. Let me know whenever you’re here visiting! I am a big fan of the United States and have visited like 20 times by now.
      what its got
      Prefix 9.0L 850 hp
      TKOSROD1287K 5TH GEN VIPER 4 WHEEL ACTIVE RIDE HEIGHT CONTROL SYSTEM
      TKOSROD1292K 5th GEN VIPER ACR RACING TOW HOOK INSERT FITS 2 CLAMP STYLE MOUNT
      TKOSROD1293K 5TH GEN VIPER RACING HIDDEN REAR TOW HOOK
      TKOSORD 1294K 03-17 VIPER BUMP STEER CORRECTION KIT
      TKOSROD1296K 03-17 VIPER CONTROL ARM BUSHING KIT
      TKOSROD1291K 5TH GEN VIPER FIRE SUPPRESSION SYSTEM
      TKOSROD1281K 5TH GEN VIPER ACR ADVANCED DOWN FORCE FRONT SPLIITER
      TKOSROD1282K 5TH GEN VIPER ACR ADVANCED DOWN FORCE REAR DIFFUSER STRAKES
      TKOSROD1283K VIPER REAR LOWER SHOCK MOUNT WITH SPHERICAL BEARING
      TKOSROD1284K 5TH GEN VIPER NO BIND SWAY BAR PILLOW BLOCKS
      TKOSROD1285K 5TH GEN VIPER RACING SEAT WITH DRIVER HEAD CONTAINMENT
      TKOSROD1286K 5TH GEN VIPER RACING BATTERY CONVERSION KIT WITH BUILT IN JUMP START
      TKOSROD1276K 5TH GEN VIPER RACING DRY SUMP OILING SYSTEM
      TKOSROD1277K 5TH GEN VIPER DIFFERENTIAL COOLER SYSTEM
      TKOSROD1278K 5THG NE VIPER HP6A REMOTE OIL FILTER ADAPTER
      TKOSROD12416K 3rd, 4th, 5th GEN VIPER RACING BRAKE LINE KIT WITH HEAT SHIELDING
      TKOSROD1300K 5TH GEN VIPER BALL JOINT HEAT SHIELDS
      TKOSROD1301K 5TH GEN VIPER ACR RACING BRAKE COOLING KIT
      TKOSROD1303K 5TH GEN VIPER ACR ALUMINUM ADVANCED DOWN FORCE WING END PLATES
      TKOSROD1304K 5TH GEN VIPER SEAT BELT SIMULATORS
      TKOSROD1390K 1996-2017 DODGE VIPER FRONT AND REAR LOWERED ADJUSTABLE SWAY BAR LINKS
      TKOSROD1388K 3rd, 4th, 5th GEN VIPER ALUMINUM BELLY PAN COOLING DUCT SCREEN
      TKOSROD1389K 5TH GEN VIPER ENGINE BELLY PAN DRY SUMP SYSTEM ONLY
      TKOSROD1391K 2013-2017 DODGE VIPER RACING TRANSMISSION MOUNT
      TKOSROD1394K 2013-2017 DODGE VIPER WIDE OPEN COMPETITION EXHAUST
      TKOSROD1396K 5TH GEN VIPER DRIVER SIDE ENGINE COMPARTMENT WIRE HARNESS HEAT SHIELD
      TKOSROD1399K-PX1114DCX6 2008-2017 PRO COMPETITION VIPER ADJUSTABLE MAX THROTTLE RESPONSE KIT
      TKOSROD1439K 2013-2017 VIPER REAR TOE LINK
      TKOSROD1450K HEAT SHIELD FOR TKOSROD1439K TOE LINK
      TKOSROD1459K 5TH GEN VIPER REAR WHEEL VENTS
      TKOSROD1460K 5TH GEN VIPER CARBON FIBER LUGGAGE COMPARTMENT FLOOR WITH BATTERY TRAP DOOR.
      TKOSROD1464K 2013-2017 5TH GEN VIPER RACING BATTERY HOLD DOWN
      TKOSROD AG-BTR-1 Antigravity Battery Tracker (LITHIUM ION BATTERIES
      TKOSROD1484K 2013-2017 5TH GEN VIPER TRIPLE DISC CARBON CLUTCH
      TKOSROD1493K 2003-2017 DODGE VIPER CAMBER CASTER LOCK OUT PLATE KIT
