Home › Forums › Gen III / Gen IV › Gen IV / V DSE Intake Heat Shields Now Ready to Ship
Awesome!
Order placed.
Thanks again, look forward to seeing the catch can mount completed shortly.
ca_viper said:
Do you need order this for the GEN IV? Or can you reuse stock items?DSE-VP-HS-002 – Gen IV Anodized Aluminum Airbox Screws (set of 2, replaces OEM 04708180) $25.00
DSE-VP-HS-004 – Gen IV Replacement Nut Clips (set of 2)
You can reuse the stock items but the thumb screws are included with the kit as well. Also make sure your car has a drain plug in good condition (not normally included in the Gen IV kit)
Thanks
Doug -
Thanks. I will check before I order.
SSGNRDZ_28 said:
You can reuse the stock items but the thumb screws are included with the kit as well. Also make sure your car has a drain plug in good condition (not normally included in the Gen IV kit)Thanks
Doug -
Production is complete and the second round of DSE shields are ready to ship effective immediately.
The shields include anodized aluminum thumb screws and the airbox drain plug for the Gen V (the plug isn’t installed from the factory on newer models).
Order here:
http://dougshelbyengineering.com/Viper.html
Installation Instructions:
http://dougshelbyengineering.com/uploads/DSE_Dodge_Viper_2008__Intake_Heat_Shield_Rev3.pdf
FLIR Test Results:
http://dougshelbyengineering.com/uploads/Feb_2015_Heat_Shield_Testing.pdf
http://driveviper.com/forums/threads/9367-Intake-heat-shield-installed-impressions
Questions? Let me know.
Thanks!
DougIMG_6725.jpgSheild-Results-Idle-vs-40-mph.jpgIMG_6773.jpgIMG_6810.jpgIMG_6010.jpg
