Titanium is light weight and a low conductor of heat, all of the below are made from Grade V or Ti 6AI-4V.
Front ACR Brake Caliper Piston Caps: The lightest weight solution to reducing transfer of heat from the pad to the caliper and reduce brake fluid temperatures on-track. Complete set of 12 pieces. Teflon infused anodize coating. Weight is 0.025 lbs per caliper.
ACR F/R Titanium Brake Pad Shields: A pad shield to reduce transfer of heat from the brake pad to the caliper and reduce brake fluid temperatures on-track. Set of 4 pieces. Weight per caliper is 0.320 lb front / 0.175 rear.
Front Caliper Cross Bolt: Reduces unsprung weight (0.1 lb per caliper), Teflon infused anodize coating.
