Home Forums Gen V Gen V fuel additive funnel.
      The funnel is primarily used for adding fuel in an emergency.
      It mount to the bottom (underside) of the panel that covers the battery in the hatch, you will see two holes pre-drilled in the corner.
      Sambo,
      Much appreciated. Thank you,
      I received the fuel additive funnel with my 2013 GTS. it is the only way to get an additive in the tank or refuel from a gas can. Obviously it must travel with the car and under the hood so as not to get a gas odor inside the car. It appears that it has two pins on it for mounting somewhere. Before I drill two holes, does anyone know where it goes?
      Thanks,
