Home › Forums › Performance Modifications › Gen V modyfication to 750hp
You’ll need heads/cam to get there.
715hp is the most I’ve seen N/A with just bolt ons. The 9.0 stroker with full bolt ons will probably get you there. Heads/cams will get you 800hp+. If you meant 750 rwhp n/a then you will need all of the above.
Bolt on plus the H/C kit for 750hp crank give or take.
Or, you can go this route for non N/A
https://www.youtube.com/watch?v=S0W7n9QMDWE
what is H/C kit ?? :confused:
H/C= Heads and Cam.
There was one shop doing a SC setup. Forgot who, but speculation was 800+. JMB maybe?
I’m looking but I have not found what I need to do to reach 750hp from n/a engine ??
