Home Forums Gen III / Gen IV GenIV Exhaust Sound Clips and Discussion
    • VIPER BAZ UK
      Well if you don’t get any clips does that mean no work for me LOL!!!!!!!
      Looks like it, But then you just want to get a Gen 4 ACR in your garage as I think its the only Viper gen you haven’t had in there to work on, No photo op for you, Lol
      But then i was out in the GTS today and bloody hell I’d forgotten the kind of statement that thing makes.
      2.5″ Corsa vs Headers, Cat Delete, 2.5″ Straight Pipes.
      [video]https://youtu.be/IQcF5q_vEIA[/video]
      Sounds much better with the 3″ all the way back now.
      [video]https://youtu.be/aVuutzqAQoE?t=13s[/video]
      Thanks, your right sounds much better with the 3″ all the way back, Did you consider or try high flow cats, seems the stock ones change the sound quite a lot
      viperdave said:
      Thanks, your right sounds much better with the 3" all the way back, Did you consider or try high flow cats, seems the stock ones change the sound quite a lot
      I built a set of Corsa 2.5″ with 2.75″ hi-flow Random Tech metal cats. 2.75″ has a lot more CFM flow than the 2.5″ if you go to build a set. No sound clips on that. Very drivable on long trips and keeps you from stinking up the folks behind you in run groups. You can see those in background on the garage floor. I built my Corsa’s and straight pipes with V-bands for easy on/off.
      Well we have a Gen V exhaust clip and discussion thread and the other gens must have been done to death by now, but what do all the Gen4 combinations sound like and just to start a riot whats the best exhaust setup on the Gen 4?
      So come on post up your sound clips and videos and tell us what you have and which is the best. Lets just hope it doesn’t end in pistols at dawn!
