Home Forums Welcome to the Viper Club How to Change your User Name/Forum Name
Viewing 7 reply threads
    • viperguy69
      To start login, on the far right your have a “Portal” tab, select it (if your user profile did not come up when you logged in)
      Next review your  Profile Detail
      On the right in blue is “Edit Profile”, select it
      The top item is “User Name”, now right below that is “Profile Display Name” change it to the name you want to see in the forum
      Now go to the very bottom and select “Update Profile”
      … or
      Just above “Update Profile” at the very bottom of the page is where you can now load your “Avatar”
      And you are done… Please note that you  now login with your new user name you selected
    • ViperSRT
      Does not work for me. The User Name selection is not selectable.  First and Last names are selectable and presumably could be changed. All 3 have asterisks which have no explanation either.  Maybe they only enable this feature for you.
    • viperguy69
      I now see that mine has the “*” as well and I cannot change it.
      I changed mine last week when we were testing.
      I will need look into this some more and get back with everyone.
    • Cobraman484
      Not working for me either.
    • Sting
      All,  It’s not *Username.  You cannot change that.  However…you can change your “Profile Display Name”.  Refresh your Profile page, and you should se “Profile Display Name” under Username.  Save and happy posting.  You can also add an Avatar if you choose to.
    • ViperSRT
      Sting not sure when but that line for Profile Display Name was recently added as was the avatar upload button.
    • NottaVette
      Thanks for the directions.  Worked for me.
    • Cobraman484
      Worked for me too, thanks.
