This is more of a question, however, I am pointing out a problem with the torque values in the manual. These questionable values have existed prior to the G5. The following is an attempt to point them out:
Maybe together we can solve this
1. Description in Manual (nm- ft lbs – in lb
Top Four Transmission To Engine Bolts 41 30 –
Bottom Four Transmission To Engine Bolts 68 50 –
Transmission To Oil Pan Bolts 30 22 200
1A –Should Be – Bell Housing to Engine:
Top Six Bell Housing To Engine Bolts 68 50 –
Bottom Four Bell Housing to Oil Pan Bolts 30 22 264
2. As far as I can see there is no accurate transmission to bell housing torque value in the viper manual
2A. (8) bolts – I believe it should be either 40 or 45 ft lbs for trans to bell housing
3. The following were changed on the G5 (from the G4)
Transmission Mount Bolts 41 30 – should be (24 ft-lbs)
Oil Pan Drain Plug 34 25 – should be (20 ft lbs)
If anyone sees anything wrong, lets discuss and solve
