Home Forums The Track INDE March 14th-15th 2015
Viewing 9 reply threads
      Also, does anyone know what configuration we will be running?
    • Nemesis
      I will be there. They will not announce the configuration until the morning of. You will get two practice sessions on what ever the declared config is. It will be a different configuration on Sunday.
      Thanks. What kind of session is it? Open passing? I’ve never done anything like this before so I have no idea. I’ve just done a couple of Nasa events.
      Thanks.
      Are you running the BRZ and the TA???
    • Nemesis
      I am racing in the spec series in the BRZ. I may also run the TA in the time attack depending on whether we get a harness issue sorted out.
      – – – Updated – – –
      What did you sign up for? HPDE or Time Attack?
      Just the HPDE… No Time Attack for me until I get a little better… I’m also running on R1’s with about 30 heat cycles, so cant get too crazy out there…
      PM me your cell number and I’ll text you, I wanna check out the TA! I’ve never seen a Gen 5 up close….
    • Nemesis
      Ill be at the track Friday evening, Eddie is coming in Friday as well. You will probably run into him at the hotel in Wilcox.
      Yeah…he should be getting thrown out by then. : )
      Have fun down there, everyone. I was going to go but ended up getting booked to play a show for St Patrick’s day so I had to take that.
      It’s a beautiful track, should be a great time.
      Nice to meet everyone, I had a blast! That’s a great track. Lot’s of tricky elevation changes etc.
      Much thanks to Debbie and Dave for setting this up!!!
      I registered, will be down there Saturday only. Who else here is going to make it?
