Home › Forums › Gen III / Gen IV › info please
It snaps off. Can’t recall exactly how at this moment but can look when I get home.
There are 2 metal clips attached to the panel on each side, they will pry up hard but will pop out.
The threaded holes may be covered with tape. There are 2:
Yeah it’s best to remove the seat if I recall correctly.
I just posted some pictures for you in the alley thread you started. Reach out via pm if you need help. I wrote a pretty good DIY, its in the vca but I’m not a member anymore Mike
Sent you a PM with a link to about how to do the install. The guys on here sent it to me when I was doing mine. Be careful when cutting the carpet on the side lap belt. It’s hard to find the bolt. I missed it the first try so my cut is much bigger than needed.
The small access panel that opens to the rollover bars and/or harness anchors, does it just snap off, or is it bolted in?
Thanks Sam
