Home Forums TKO Motorsports, LLC Install bushings to improve performance and lower lap times
    • 13COBRA
      I installed control arm bushing kit last year on my Gen IV ACR and absolutely loved them. It was amazing how much smoother and tighter the steering felt with just that change alone. HUGE improvement for a super minimal cost.
      TKOSROD1296K 2003-2017 GEN VIPER CONTROL ARM BUSHING KIT
      Correct the mushy feeling under heavy braking conditions and the loose feeling in high load turns of your factory rubber control arm bushings. More precise handling under extreme conditions. Machined from an ultra-high molecular weight, self-lubricating based plastic giving these bushings incredible strength and great lubricity properties far superior to urethane or rubber.
      Kit comes complete with:
      • Front and rear control arms upper and lower; complete set
      • Alloy steel bolt sleeve bushings electroless nickel plated
      • Bushings assembled and ready for installation
      PERFORMANCE IMPROVEMENTS
      . Customers who have installed our control arm bushing kits have seen anywhere from 1-3 seconds faster lap times.
      . Free suspension travel, no binding or added torsional spring load that rubber bushings induce.
      . Much easier to install then factory rubber bushings
      . No more worrying about cracked or rotting rubber bushings
      We have had requests from customers and VOA members to indicate what performance benefits customer may see when installing our parts and products ………basically ” bang for your buck”. So from now on when we promote the products we design, engineer and build we will add some simple info about ” PERFORMANCE IMPROVEMENTS”, ” reduced lap times”, ” ease of use” etc etc. Most of this information will be directly from our customers who have installed and used the product.
      TKOSROD1497K 2013-2017 DODGE VIPER LIGHT WEIGHT BILLET ALUMINUM STEERING RACK BUSHINGS
      TKO Motorsports light weight billet aluminum steering rack bushings are a very simple and effective way to increase your dodge vipers steering performance.
      ? More precise steering feel
      ? Increased steering reaction to driver input
      ? Les driver fatigue
      ? TKO Motorsports kit will not cause premature steering rack wear or failure.
      Never install billet aluminum steer rack spacers on both passenger and driver side or your dodge viper. Installing solid rack spacers on both passenger and driver side will cause increased steering rack wear and premature steering rack failure.
      WHAT THE KIT COMES WITH
      ? Light weight billet aluminum steering rack bushings DRIVER SIDE ONLY
      ? All necessary hardware for installation
      ? Installation instructions with detailed pictures
      ? TKO Motorsports life time warranty and tech support
      PEFORMANCE IMPROVEMENTS
      . More precise steering feel at speed
      . Track vipers the bushings will especially improve turn in speed so steering will feel much quicker
      . Better driver steering feed back through the wheel. You can feel more of how the tire is interfacing with track surface and track conditions.
