Good morning.
I recently had my rack out for a seal and put everything back together but now have play in the steering wheel.
Maybe 1-2mm or so. I noticed the upper joint in the shaft where it slides can be rotated slightly before the rest of the shaft moves. Is the torque on those bolts only 30lb, or is that for the other bolts where it connects to the steering column and rack? Or is there something else I may have missed?
Thank you.
