there are v shaped cutouts on the frame just behind the front tire and in front of the rear tire just beyond the sills. That is the best place. JAcking up the rear will lift the whole side of the car.
gen V has the same V frame spots. And when I changed my oil last week I jacked the car up by the rear V lifting the entire side of the car and I placed my jack stand under the front V. Then repeated for the other side. Aside from needing a low profile jack it’s the easiest car I’ve had to jack up, there’s no question where you should be lifting it from underneath.
Just wondering if anyone has any pictures of underside of ACR with proper place to put jack??Don’t want to damage panel with wrong placement.Also curious what you use for car stands,and placement.Thanks in advance,Dan
