Home Forums Gen V Launch control question
      RPM will hover between 5000-5500, depending on temperature outside.
      In 1st gear, clutch pedal to the floor, arm via steering wheel, then floor the gas pedal and hold it. Release clutch quickly, whenever ready. Don’t lift gas pedal.
    • dmc71
      Ok, thanks. I was probably not flooring gas pedal quick enough or all the way down which caused launch to abort and RPM’s were going above redline.
      Tried launching multiple times today but I’m missing something. When you press the pedal all the way to the floor in launch control in less than 0.5 seconds as the manual states, are the RPM’s supposed to red line or is the car suppose to limit at 4500 RPM’s?
