Home Forums Gen I / Gen II Many thanks, JonB….for the Gen II…
      Hard to beat that split-hub design and the quality of construction!
      Top notch stuff Jonb , getting bracket and pulley installed next week along with some other goodies…
    • Leslie
      Jonb ROCKS!
      Before you guys replace your pulleys, check the high pressure p/s hose where it curves under the p/s reservoir for any damage. Mine had a nice ‘V’ shaped groove rubbed into it from where it was touching the p/s reservoir. While you’re replacing the pulley, you might as well replace the hose if it is damaged.
      Will a Gen I pulley fit on a Gen II pump (are they the same?) I know the Gen I was a metal pulley so it doesn’t have the issues the Gen II plastic one does (even though the bracket should still also be replaced).
      Also, any chance any of the early GTS’s used the metal pulley?
    • XSnake
      Thawk97 said:
      Will a Gen I pulley fit on a Gen II pump (are they the same?) I know the Gen I was a metal pulley so it doesn't have the issues the Gen II plastic one does (even though the bracket should still also be replaced).
      Yes, it does fit.
      …billet power steering pulley and bracket!!
      Also, thanks for the lights…will distribute said gifts at our April meeting.
