pokeyl said:
Stock is .544
710r is .603/.606 I know I have to do springs with it
Can I use the Crower .573 lift with stock springs?
Thanks
I feel as if the stock valve springs aren’t great by any means and are almost capped out with the stock cam profile. Even with the Crower cam you speak of I’m going to assume you would need to upgrade your stock springs. Go to JMBperformance.com, Justin has some great cam profiles for NA as well as FI setups. He can even do a complete custom grind for you if you’d like. If I were you I would just accept the fact that you are going to need to upgrade your springs. Good Luck!
