Home Forums Gen III / Gen IV My 0-60 MPH 60ft & 1/8 mile times via GTech Pro SS
      Hey good times, about average, your car is probably quicker that that, prob at your run 3 or better, mine did the same numbers at rockingham last summer, hopefully we’ll see you there this year and you’ll have better data., welcome to the VOA, did you check the Carolinas sub forums yet?.
      The 60 ft time suck. Should be down to 1.6 – 1.8 but that at the track not at the road. I was more interested if anyone as ever verified the results of the GTech while at a track to test its accuracy. I verified the cruising MPH at 40 – 50 – 60 – 70 against my Garmin GPS Right on…but the Viper’s odometer was off by 2 MPH from 40 -70.
      A new member here. First want to say great site…great reference info.
      Took the viper (2004 Stock w/Michelin Super Sports) out on an empty road using the GTech with the following results
      First three runs had approx 5-6 gallons of gas in the tank
      Last two runs full tank
      Run 1 __ 60′ was 2.2 __ 0-60 MPH was 4.06 __ 1/8 Mile was 8.04
      Run 2 __ 60′ was 2.1 __ 0-60 MPH was 4.02 __ 1/8 Mile was 8.01
      Run 3 __ 60′ was 1.9 __ 0-60 MPH was 3.97 __ 1/8 Mile was 7.86
      Run 4 __ 60′ was 2.3 __ 0-60 MPH was 4.37 __ 1/8 Mile was 8.35
      Run 5 __ 60′ was 2.3 __ 0-60 MPH was 4.35 __ 1/8 Mile was 8.25
      Last two runs were at a different location w/full tank of gas. Didn’t want to press my luck with to many runs at the same place. Weight of extra fuel and road surfaces may be the differences in results
      Has anyone ever used a current model of the GTech purchased between (2010-2014) at a track to verify the results.
