Home Forums Ontario Need advice Passenger Side Motor Mount
      Remove the air cleaner housing
      Remove the steel bar that goes side to side under the housing
      I keep the nut on the drivers side mount but leave it loose
      Using a flat piece of wood jack the oil pan. (Careful the car can shift)
      Keep on rotating the mount around until it comes out.
      Note: If you need to remove the oil pan or the passenger side exhaust manifold in the near future then wait. The mount falls out.
      Thanks Garron, Its tight on the passenger side, will try it with the nut on driver side. Will call soon when the pinion gears come in, should be soon. The Borla exhaust just slipped on. Have a great holiday season.
      Hoping for short winter new Cat Backs installed, hoping to reduce cabin heat. Pulled rear differential out waiting for new 355 gears to be delivered, Changed driver side motor mount ( finally figured out what the creaking was coming from) no problem but don’t have enough room to remove passenger side motor mounts, hoping someone has a few tricks to try. Wish everyone the best during the holiday season and see you again in spring.
