Good Morning everyone,
VIPER PARTS USA is excited to announce our 1st New Product for 2017. A complete Rear Differential Oil Cooler Kit for your 2003 – 2017 Dodge Viper.
Under stressful conditions, the oil in the differential can easily overheat and break down, potentially causing damage to the internal components. Our cooler with its thermostatically controlled pump, will keep oil temperatures within Manufacturers recommendations and add additional 50% more oil capacity to the system which will help ensure plenty of cool lubricant for your Differential.
Please Note: A differential cooler is recommended by FCA in the ACR Supplement Manual for track outings.
Your system will be tailored and built for your specific year Viper, comes complete with Cooler/Fan Assy, Severe Duty Lubrication pump, Wiring, Sensor, Hoses, Fittings, Mounting Brackets and detailed photo installation instructions.
Call with your vehicle details for system specific pricing.
Our Kit contains only the Best Components:
+ Aeroquip Kevlar Startlite Hose with pressure ratings to 400PSI and temperature to +300 degrees F.
+ Eaton and Aeroquip Fittings.
+ Bosch Relays and Carling Switches for reliability, longevity.
+ Tilton Brand Continuous Duty rated fluid pumps. These are the same pumps the Professional Racers use.
+ We recommend the optional Joe Gibb’s Racing Extreme Duty Differential Lubricants. Manufactured to withstand
the extremes of NASCAR, ALMS and our Hi-Performance use.
