Home › Forums › The Track › Nitrogen tank & hose
Any reputable welding supply company.
Blue T/A 2.0 said:Any reputable welding supply company.
Thanks. I seem to be having a hard time finding the connection to the wand. It’s an M14X1.5 fitting, and it seems most hoses want a 1/4″ ID fitting.
Maybe I can just change the fitting in the wand?
Or you can use a reducer/adapter. I believe that’s what I have (can check when I’m back home)
38D said:Or you can use a reducer/adapter. I believe that's what I have (can check when I'm back home)
Thanks. I’m driving myself nuts trying to find an adapter on line.
Where is a good place to get a proper nitrogen tank, regulator and hose from for an air jack system? I have the Krontec easy push wand already.
