Home › Forums › Gen III / Gen IV › Oil Dip Stick pushing out of tube
Sounds like you’ve got a blocked crank case breather tube, and the pressure is pushing the dip stick out.
Sounds like your crank case isn’t venting properly. What’s your PCV setup?
Steve M said:Sounds like your crank case isn't venting properly. What's your PCV setup?
The engine is stock except for the headers.
I’d check your PCV valve…Gen 3 or Gen 4? I know where to look on the Gen 4, but not as familiar with the Gen 3…
What did they gap the rings at?
Garron said:What did they gap the rings at?
I will need to check the build sheet for the ring gap.
Has anyone else had a problem with the oil dip stick pushing out a few inches? I rebuilt the motor and have about 1000 miles on the engine. The oil is going everywhere and ruined the ceramic coating on my headers.
