Home Forums Gen III / Gen IV Power window relay location????
      Try unplugging the relay, the BCM also control’s the power windows.
      Called the wizard today and found the answer. The drivers window has a individual relay but the pass window relay is built into the BCM. And even with key off the BCM is telling the window to constantly roll up. Even with the reg unplugged so that rules out the regulator causing it. Too bad i didnt figure this out before ordering a pass regulator but since on national backorder should be easy to sell
      My passenger window is in constant up mode. Im not sure if the regulator can go bad and do this or if there is a relay that controls the window stuck. Ive already swapped the center console switches to make sure its not a stuck switch. Oh and it does it all the time constant even when key is off too and kills the battery. Thats why i thought maybe a stuck relay. Any suggestions?
