Home Forums Gen I / Gen II quot Going it alone quot with GTS inspection wish me luck
      Local GTS folks generously offered to help, but timing is bad for them, so I’m on my own.
      Sounds like fun! I got this. 🙂
      Realistically I will find some things, but really want to nail down if nose has been worked on or replaced. Pictures show more-than-comfortable gaps between nose/hood.
      Inspection for Under hood, brakes, exhaust:
      • Front damage repair indications when inspecting under hood? (I COULD USE SOME COMMENTS from you guys)
      • Blue overspray
      • PS Pump….Plastic pully? | | |
      • Cast Iron manafold w/stainless shield | | |
      • Stock stainless exhaust w/stainless rear tips | | |
      • Stock brakes black w/white letters | | |
      • Check fittings for rust (scale 1-5 5-sucks)
      Exterior Inspection
      • Front damage repair indications when inspecting? (I COULD USE SOME COMMENTS from you guys)
      • Tires….original? (Michelin Pilot SX). | | |
      • Original wheels have no rash? | | |
      • I hate chrome add-ons, etc.
      • Polished Aluminium Gas Lid | | |
      • Front Spoiler underside condition(describe)
      • CHECK FOR ORIGINAL PAINT
      o Mesh Tape on leading-edge of wheel well facing kick-panel | | |
      o Mesh Tape on trailing-edge underside of nose before wheel-well | | |
      o No blue overspray | | |
      o Edge of hood/door paint should be smooth
      o CHECK STRIPE PAINT…will have slight ridge? | | |
      • Door sag and fit. | | |
      • Check weather stripping | | |
      • Headlight levels | | |
      • Hood corners rear/front any(!!) damage? | | |
      Interior
      • Rocker Panel Blistering (heat)? | | |
      • Kick Stickers correct white/complete? | | |
      • VIN label matches window/title? | | |
      • Hook up code scanner…not sure if this really gives anything on 1st-year ODB2 coded car.
      When time to start car:
      • Stay outside and watch for smoke. | | |
      • Car with have lope….is ok
      • Note dash lights with key “on”….all eight should light. | | |
      • Note dash lights with car running….eventually they go out | | |
      • O-pressure….rafter drive, temp, o-pres
      Research
      • Were recalls 998,999 done? No mention on CarFax…will inspect front for 998.
      • CARFAX OK? | | |
      Underside Inspection
      • Fittings rust (1-5)
      • Frame rust (1-5)
      • Welds rust (1-5)
      • Paint (1-5)
      • Bottom-out scapes
      • Wheel-well scrabes, nose scrapes
      • nose backside cracks or repairs.
      • Front damage indications when inspecting underside? (I COULD USE SOME COMMENTS from you guys)
      • Recall 998
      o Steering Rack Mount Welds | | |
      o Left Side Differential Mounts Will not be able to inspect
      Test drive
      Go through gears | | |
      Clutch OK? Have owner take to 70ish in 5th, then punch it to check for slip | | |
