Stradman, not an expert with failed G5 motors but the reoccurring issue seems to be block contamination/issues, not oil starvation coming from high G loads. A number of the motor problem cars are just being street driven. Not aware of any G5 cars with a dry-sump but I’m sure if there are they’ll comment to your thread.
A number of comp coupes are using them (not mine). Seems that Dailey is the one I hear about the most, but there’s others building them too Good luck, Mike
http://www.daileyengineering.com/dailey_engineering_home.htm
Cheers Mike,
Yes contamination has been one possible issue as you suggest. But short of disassembling the motor, and cleaning/rinsing out and blueprinting you probably won’t have such an issue through that. The spun bearings we have heard about may also be a compound problem i.e. debris and oil starvation. It seems to me if you can avoid any possibility of oil starvation via a dry sump set up in heavy track use, then this may help soften or offset the impact of possible debris. Just saying….. -
I believe Calvo is doing dry sumps for the Vs.
Quick question, I was speaking to a tuner in Germany(Geiger) who suggests I dry sump my ACR-E if I want to use it for regular serious track days. He says he’s seen 2 cars with spun bearings there and since dry sumping his cars, he hasn’t had a problem. I know the Gen V’s have this swing arm pick up but that will never be as good as a good dry sump. So in light of the fair few engine failures that have occured that I have read about- which may possibly be implicated through some degree of oil starvation, have any of you regular track users put in a dry sump in your ACR’s?
