Home Forums Gen III / Gen IV SCT data logging with Torrie
      What mods do you have done?
      And torrie is at Unleashed Tuning, correct?
      Unleashed Tuning is correct. ATI damper with ATI paxton pulley, 69lb injectors, 2 bar map, JTS Venom throttle body, gen 4 fuel pump, DLM upgraded cooler and pump, DLM belt tensioner, AEM failsafe wideband, oil pan swing arm upgrade, headers, cat less borla exhaust,170 deg thermostat, cooler plugs with larger plug wires, oil catch can, That’s the engine and associated mods for tuning.
    • thetalonguy
      That’s great!
      Torrie is a great and extremely responsive. I worked with him in December to adjust a custom SCT tune I purchased from him. Talk about an immediate response, wow.
      After I do a few more upgrades down the road, I’m going have him do a remote dyno tune.
      Good luck at the track!
      I can’t really put into words how bad azz the viper is with the drivability tuning done with the X3 and Torrie! I had the Viper remote Dynoed with Tony Working with Torrie and it had a safe WOT tune putting down great #s but after the drivability tuning done it really has made a difference for all around driving. The car responds like a NA car through the throttle input range but with lots more pucker factor. If anybody out there has only done a dyno tune I would highly recommend doing drivability tuning with the X3 and Torrie! Now I can’t wait for Chinn at Road Atlanta in March.
      O, and if you don’t have a X3 Torrie can sell you one also.
      :smileys-car-driving
