So I recently changed and upgraded my 2009 Viper’s brakes with StopTech Rotors, SS lines, and Stoptech STR 660 brake fluid. I have roughly 17k miles on it. I track the car 5 to 6 times a year. Im over due for rear diff fluid replacement & trans fluid change. I plan on doing this ASAP as track season is upon us. I’ve been searching a lot of the forums and have only grown more confused as to what fluids I should use. I understand the OEM recommendations but I track my car and if I can get fluids that out perform the factory one I would prefer that route. I feel it’s just preventative maintenance given what the car goes through on the track.
1. What diff fluid has anyone seen hold up the best? I understand there’s the friction modifier to add but now Mopar and Castrol have fluid with the modifier already added in now. Some like Royal Purple have added in friction modifier too. But is the Royal Purple friction modifier up to the same specs as the OEM friction modifier? Or maybe the Royal Purple exceeds it? Or if you use the Royal Purple maybe one should add the OEM friction modifier to it too?
2. On the trans fluid I read people using all different types of brands, I just want whatever one will hold up the longest under high temp conditions on the track. Anyone have a recommendation from past experience?
3. If the clutch fluid takes just DOT 4 brake fluid would it be fine to just use the Stoptech 660 brake fluid that Im using now. It’s high temp brake fluid which I understand absorbs moisture thus requires more frequent brake bleeding, (which I’m ok with doing), but would that have any ill effect on the clutch?
Thanks in advance for any suggestions. Im just trying to make sure I use the best in my vehicle.
