Home Forums Gen I / Gen II small hole in soft top
    • 01sapphirebob
      yellowviper said:
      I have a 2001 RT/10 with a very small hole in the soft top- about a 16th of an inch in diameter. Any ideas how to fix or repair this? Appreciate your suggestions. Jack
      As silly as this sounds I simply used an iron on patch on the underside of the top to fix it. Worked like a charm
    • plumcrazy
      id find a shop that works on boat interiors and boat plastic windows. they can always fix stuff like that
      Jack, there is a place called Auto Interiors and Tops in downtown Raleigh, and they can repair that hole. Give them a call and see what they can do for you.
      I did the same thing on mine and it worked fine.
    • jwolf
      Mine didn’t have a hole but it had two place that were wearing thin from rubbing when folded in the trunk, I used the black iron on jean repair on the inside and it worked great.
