Get a black Denim patch like you would use on jeans. They work great. If you are not comfortable doing it yourself, take it to your local interior shop. Easy and cheap.
99RT10 said: Get a black Denim patch like you would use on jeans. They work great. If you are not comfortable doing it yourself, take it to your local interior shop. Easy and cheap.
I did this to my top (on the inside) before any issues started. It was a great way to reinforce the areas prone to wear.
I have a 98 rt/10. The soft top has a very small tear in it. Did not go all the way through. it is just below surface. About 1/4″. Any suggestions what to put on it to keep it from getting worse. I put a piece of Monster tape on the underside. About a 1″ piece. Cannot see it because it is all the way in the back. Any thoughts or suggestions would help. Thank you.
