Rack Stops: Stronger than the OEM plastic which are prone to breaking
Bellows/Boots: Flexible neoprene upgrade from the OEM version. Includes OEM style clamps.
Inner Tie Rods: Improved over OEM which can pull out over time with heavy track use. Cadmium plated 4340 steel, aerospace grade bearing with PTFE liner. Lower friction and higher strength than OEM.
Aluminum Rack Bushing: Replaces the stock rubber bushing with high strength CNC machined type III black anodized aluminum bushing. This will dramatically increase steering responsiveness, and reduce vibration that can be felt in the steering wheel.
Ti Rack Bolts: Set of 2 titanium bolts coated in Teflon infused anodizing saves weight over OEM. Includes Type III hard anodized black aluminum washer.
