Home Forums Gen III / Gen IV Stock Caliper question
      2008 parts list shows 38 & 42 mm pistons on the rear, and 40 & 44 mm pistons on the fronts.
      Piston size will be the difference as indicated above…the calipers are physically the same size, but the pistons are not.
      Thank you fellas
      About to put stock resealed calipers back on my track car. Dumb question of the day:
      Is there a difference between the front and back caliper? If so, how can you id them?
      I know the bleeders go up, orientation and such. Just trying not to do something stupid here.
      Thanks in advance
