Home Forums Tire , Wheel, Brake and Suspension Suspension Fitment
      95Viper said:
      Anyone put Gen 2 Aluminum Control arms on a Gen 1? or will they even fit? They look so much better than the tubing ones…
      Won’t work, you would need to cut off all the frame mounts and totally redo the set up, gets very expensive.
    • 2Luke2
      If you decide to take it on, I don’t mind providing measurements for anything you might need want. We are replacing pretty much the whole suspension besides the arms/wheel bearings themselves. Everything but not limited to the control bushings, upper and lower ball joints, coilovers, inner/outer tie rods, end links, SS brake lines, calipers, and rotors.
      I’ll sell you a bent front clip. The frame is all bent up but the A-Arm mounts are good…The Arms weren’t bent!
      <---------- This One!
