That’s very cool!
Great idea and carried out perfectly!!!
SRTGill said:
The inevitable question, can you produce another clock and how much? lolTechnically, yes I could print more, and in theory I could knock one out using the Sneaky Pete or Fangs logo. However, I’m not sure anyone would be willing to pay enough to make it worth my while. I learned a ton from my project and have some ideas on how to improve it, but it will require a complete rebuild of the 3D model. The striping makes more work too, and I’d need to be able to finance a new larger printer before attempting this again – the main body of my clock is 42 pieces which is just a pain to assemble so being able to print larger pieces would remove a ton of headaches.
FUSRODAH said:
Technically, yes I could print more, and in theory I could knock one out using the Sneaky Pete or Fangs logo. However, I'm not sure anyone would be willing to pay enough to make it worth my while. I learned a ton from my project and have some ideas on how to improve it, but it will require a complete rebuild of the 3D model. The striping makes more work too, and I'd need to be able to finance a new larger printer before attempting this again – the main body of my clock is 42 pieces which is just a pain to assemble so being able to print larger pieces would remove a ton of headaches.Gotcha, thanks for the info!
I didn’t know what to do with all the old brake discs and pads, spark plugs, differential gears, clutches and so on.
So i decided to make a Viper Garage Clock.
That’s what came out of it :):D;) -
Super use of old/broken parts!!!!
Those are some heavy ass clocks lol
I got plenty bored being stuck in the house all winter so I spent way too much time with my 3D printer making a new clock to hang in my garage. It’s about 3 feet wide and wasn’t super stable when I first assembled it, but I eventually worked around that by printing a few extra support pieces to make it more rigid.
Unfortunately, I hated how it looked with white walls, so I ended up repainting my whole garage and now I’m debating doing an epoxy floor — this thing has turned into way more time and money than I was expecting, but it looks pretty nice now that I’ve finally got it hanging up.
The lighting in my garage isn’t great for pictures, but you get the idea:
