Home Forums Gen V Tire amp Wheel Information
      Just some miscellaneous tire/wheel combo’s with weights:
      Note: The following are actual field weights and measurements, they were not taken from the manufacturer’s spec’s. All weights were from the same scale, however, differential weights could be off by 1 lb due to the ½ lb scale increments.
      Rear
      1. 19” sidewinder oem wheel with factory Corsa: 57.5 lbs
      2. 19” sidewinder oem wheel with Toyo R888r: 60.5 lbs
      3. 18” Gen 2 oem wheel with Mickey Thompson 345 x R18 ET Street S/S DR: 69.5 lbs (requires 1” spacer)
      4. 18” Forgeline with Mickey Thompson 345 35 R18 ET Street S/S DR: 61 lbs
      5. 18” Forgeline with Mickey Thompson 325 35 R18 ET Street R DR: 57 lbs (same measured width/diameter as 345)
      Front
      6. 18” sidewinder oem wheel with factory Corsa: 44.5 lbs
      7. 17” Front Runner with 26 x 6.00R17 skinny: 37 lbs (25.5” diameter)
