Home Forums Gen V tire pressure sensors for a 2nd set of track wheels
    • MoparBoyy
      they should learn on their own, but it could take some time/few miles.
      The tps on the G5 seem to be very accurate.
      05Commemorative said:
      anybody have experience with this for GenV. I like the air pressure dash showing for each wheel (understand not the most accurate).
      If I get another set with the pressure sensors, does it just work or require programming from the dealer like prior models?
      Sorry Jack, meant accurate for the track to the 1/10 of lb. Since on the dash only show even lbs. I thought you had separate wheels for the track/strip, do you have tps in them?
      Yes, they automatically sync to your car, no programming necessary when swapping between wheel sets.
      I find that they work very well. In fact, I rarely check air pressure with a gage after a session. By the time I do a cool down lap and pull into the paddock, the tires have begun to cool, so instead I rely on the sensors for hot pressure.
