Home Forums Gen V TKO racing oil pan
      That new part deserves a thread… it looks like another must-have part from TKO
      https://tkomotorsports.com/product/2003-2017-viper-tko-racing-oil-pan/
      I have tons of questions, but first:
      how does it compare to the Compe Coupe pan (that I have on my car) ?
      will this eliminate the need for an Accusump ??
      DESCRIPTION
      This product is build to order!
      The factory oil pan on your 2003-2017 Viper has insufficient oil capacity which can cause engine oil starvation and in turn will result in premature engine failure.
      TKO Motorsports Viper Racing Oil Pan helps guard against engine oil starvation even in the most demanding racing conditions.
      Increased oil capacity, 11+ qt.
      Larger oil pick-up sump area
      Trap doors and baffles to keep oil in pick up sump under high G loading
      All aluminum construction
      Lighter and stronger than the factory oil pan
      Built in windage tray and crank scrapper
      Built in turbo oil return line for turbo applications
      Uses factory dip stick
      Direct bolt-on no; modifications necessary
