Home › Forums › TKO Motorsports, LLC › Tko tips and track tweaks tweaks and track tips
Woot! I’m still working out what spring rates to run front and rear for a stock power car with ACRE Aero. I have heard so many different opinions but I want to hear from the people that actually track their cars and have played with different rates.
Can you elaborate what rates you recommend and why/how they compare to other rates?
Also any tips on alignment setups for slicks? I’m running Hoosier A7s.
pMak26 said:
Woot! I'm still working out what spring rates to run front and rear for a stock power car with ACRE Aero. I have heard so many different opinions but I want to hear from the people that actually track their cars and have played with different rates.Can you elaborate what rates you recommend and why/how they compare to other rates?
Also any tips on alignment setups for slicks? I'm running Hoosier A7s.
Hello Pmak
This question is a little more advanced for our beginner TKO6T discussion like we are planning for this friday. Lets see what we can do right now to help answer your questions.There are so many variables when it comes to setting up shocks, springs, aero and suspension. When you have a sh-t ton of variables there is always going to be more then one way to do it and get results.
Here is what we run on a few street/track ACR-E vipers. Most all the customers vipers we setup also have just about every part we mfg on it and cars are balanced so they all have a good foundation for setup efficiency. This doesnt mean the info Im giving you doesnt apply we just have to adjust a bit for your specific setup.1. TKO dbl adjust race shocks w/ARHC system all for corners
2. 600-700 LB TKO front springs
3. 1300-1400lb TKO rear springs
4. TKO progressive bump rubbers all around with packers in rear at some tracksSETUP
Frt
caster 7deg Basically max out if your running any bushed factory control arm
Camber 2.5-2.7 anything more you get excessive tire wear. You can run 3+ and car is fast for 2-5 laps and then falls of like stone
Toe out .062-.125Rear
caster as close to zero as possible
Camber 2.5-2.7
toe in .062-.125Rake .250-.500″
Ride height
Race and open track season are just around the corner so once again its time to start TKO tips and track tweaks…tweaks and track tips
First TKO6t we are going to focus on people new to the motorsports community and welcome you. Maybe you just purchased a viper or any car for that matter and your itching to take it to the track to see what you and your car can do; but you dont know where to start or even how to start. We will try and answer all the most common questions of beginners. How to get on track, Car prep, driver prep, gear and safety. If your new to the motorsports world and have a specific question you just cant seem to get an answer for let us know and we will do our best to answer it. Remember everyone was once a beginner……….EVERYONE
