Home Forums TKO Motorsports, LLC Tko viper active ride height control system arhc
    • Bryan Savage
    • TKO MOTORSPORTS TEAM
      Thanks Bryan. Lot of engineering and testing has gone into our ARHC viper kit. We give you a better shock then ohlins or penske can offer you and on top of that we added our ARHC system. Its also a complete kit springs, shocks everything you need so your not hunting for springs or re using your mount like penske and ohlins have you do. We also custom build the shocks and spring package for your application we dont do one size fits all like BC coil overs, aldan, or afco.
    • Bill Pemberton
      Lots of engineering and testing going into this system is an understatement. The beauty of this system is that Dave and TKO Motorsports have the same thing going for them that we all have , and it is an unbridled passion for the Viper. TKO doesn’t just show their passion , they have put an insane amount of work behind a vehicle no longer being made. I would wager there is no other
      active ride height system comparable to this for our Snake. Like Bryan , blown away, and so cool some of the Sponsors on this site are still spending time, money and energy to make things for our favorite machine.
      TKOSROD1287K 9995.041-3.jpgtko_arch-2_375.pngDSC00082.jpg007-1.jpg[/ATTAC008.jpg
      5TH GEN VIPER 4 WHEEL ACTIVE RIDE HIEGHT CONTROL SYSTEM A.R.H.C
      TKO Motorsports ARHC (Active Ride Height Control) is a revolutionary remote-controlled hydraulic suspension system specifically designed and engineered to perform in the most extreme and demanding racing environments. This is not a leaky, bulky, lack of performance air bag system. ARHC is a very high quality, precise system that allows you to raise and lower your vehicle anywhere from 1 to 6 inches on the fly. Driveways, speed bumps, curbs, trailer ramps are not a problem anymore with TKO MOTORSPORTS ARHC system. System includes 4 custom built for your application and dyno tuned TKO Motorsports light weight (3 lbs. lighter than factory shocks) aluminum double adjustable racing shocks. Each shock has the ARHC system built in, and all shocks come with springs. All necessary hardware and instructions for simple quick installation included. TKO Motorsports shocks are 100% rebuild able and tune-able with over 100K different valving and piston combinations available. Each shock has 100% trace ability. Every shock has its own serial number, build sheet, application notes and driver preferences. All TKO Motorsports products are backed up with customer support and technical assistance every step of the way. TKO shocks are the last shocks you will ever have to purchase for your vehicle.
      SYSTEM INCLUDES
