Home Forums TKO Motorsports, LLC Tkosrod1284k 5th gen viper no bind sway bar pillow blocks
    • Aevus
      Does it fit gen 3 ?
    • TKO MOTORSPORTS TEAM
      Aevus said:
      Does it fit gen 3 ?
      Gen 3,4 we have not personally checked fit here in the shop. More then likely no problem on the front sway bar for gen 3,4. The rear sway bar gen 3 ,4 there were different diameters and shaped bars. If you have your bar diameter and pics we can take a look
      TKOSROD1284K 5TH GEN VIPER NO BIND SWAY BAR PILLOW BLOCKS 913.78 complete set front and rear
      Urethane or rubber sway bar pillow blocks bind up your sway bar not allowing it to function correctly. Billet aluminum style pillow blocks with bearings also cause the sway bar to bind up severely during cornering causing your car to be loose in the rear and pushy in the front.
      With our race proven TKO Motorsports No Bind Pillow Blocks your sway bars will not bind even under the most demanding racing conditions allowing the sway bars to function correctly during cornering and stay neutral on the straights. Our no bind pillow blocks used with our adjustable sway bar end links are one of the best performance improvements for any Viper.
      Kit comes complete with:
      • 2 front billet aluminum no bind sway bar pillow blocks
      • 2 rear billet aluminum no bind sway bar pillow blocks
      All prices include credit card processing fee
