TKOSROD1294K 2003-2017 VIPER BUMP-STEER CORRECTION KIT 767.66
Our Bump-Steer Correction Kit will cure the unstable and darty feeling experienced at higher speeds and under heavy braking loads. Billet aluminum tie rods, high strength alloy steel steer pins, alloy steel bumps steer shims, ultra corrosion resistant coatings on all parts, and heavy-duty spherical bearing rod ends. Our Bump-Steer Correction Kit is a must for viper on track performance.
