Home › Forums › TKO Motorsports, LLC › Tkosrod1493k 2003 2017 dodge viper camber caster lock out plate kit
Yes we will have pics in couple weeks of installed caster camber lock out plates as well as install instructions on line at tkomotorsports.com
DZnutz said:
Can we see these installed?TKO MOTORSPORTS TEAM said:
Yes we will have pics in couple weeks of installed caster camber lock out plates as well as install instructions on line at tkomotorsports.comShhhh…
13COBRA said:
Shhhh…thanks for posting pics 13cobra saved us a little time.
How much are they
2003-2017 DODGE VIPER CAMBER CASTER LOCK OUT PLATE KIT
A big problem with the dodge vipers is keeping your suspension in proper adjustment. Hard driving or driving your viper on track many times will result in your suspension coming out of adjustment due to the poor design of the factory suspension adjusters. Excessive tire wear, poor performance are common problems when your viper suspension is out of adjustment; You also have the added expense of constantly correcting out of adjustment suspension.
TKO motorsports camber caster lock out plates solve the viper suspension out of adjustment problem. Easy to install
Complete kit front and rear
Any reputable alignment shop can perform installation and adjustment
Suspension will stay in adjustment even under the most intense racing conditions
Wedge cam eccentric adjuster provides easy precise adjustment
Manufactured from aerospace alloy
Light weight and extremely strong
Designed , engineered, and tested for extreme racing applications
Works with factory rubber bushings or TKO control arm bushings.
