I would definitely not run toe out in the rear. Whenever I run slicks, albeit on a non-viper, I typically needed more negative camber than a R compound; roughly another -0.5 worth front and rear.
As the title states I’m running pirelli slicks for the first time on my ta and would like to know what alignment settings are you guys running especially toe figures. Last time on track was on the pirelli corsa i had run the acr alignment which was -2.8 fr and -1.7 rr with stock toe ( both toe in fr and rr) . Had some understeer in a couple of corners but I’m thinking of having the front toe out and either 0 toe in the rear or a little bit toe out as well. Would like to know the input of others that run the pirelli slicks before. They are the same sizes as the acrx tires on sw2.
